#120913
I want to put pneumatic tires on a F150 Raptor Powerwheels.
In the past, I referenced a site http://www.saltydog.com/powerwheels that had some pictures that showed how to put 13" x 5" lawn tractor tires on the F150. That site, however, is no longer alive.
I'd like to go with this option, but I need a "how to" guide or something like that. I am open to other options besides the 13 x 5 tires, but I'm not interested in attaching tire tread to the existing plastic tires.
Can anyone help?
Thanks so much!
#138757
a few years late with the reply (sorry).. but I just came across your post after searching on doing the same thing.. the site you are referencing is still active, and I've actually used that as a guideline to put new tires on my Ford F150 monster traction. The tires I'm going to use are the Arnold 15" x 6 diamter (6.5" tread).. You just need 2 wheel driver http://hobbymasters.com/power-wheels-dr ... 4460-2249/ (depends on your gearbox).. some Water PEX Pipe to convert the 5/8" to 1/2" axle size some bolts and nuts to pressure fit the driver on, and some new wheel push nuts for the front tires.. that's really all there is to it.
If your sole purpose for the charger is charging s[…]
Razor Crazy Cart 1000W
Hey guys, I just scored myself a crazy cart, curr[…]
Parting Barbie Mustang
Do you have the brake light panel still for this? […]
So my wife has a 2010 Mustang GT and we decided to[…]
