By mtran1978
#125876
I purchased a Lil Dune Racer http://www.toysrus.com/buy/ride-ons/pow ... 4-17020636 about 4 weeks ago I upgraded the battery to 12 volt. My son has been riding it on mostly concrete and grass. Now the wheels are worn and the back tire is splitting down the middle. What are my options? Should I buy new tires will they wear out just as fast? Can I fix the current ones? Thanks in Advanced.
By MattyGNC
#125912
Once they split they're done. Check ebay for new or gently used ones. Hobbymasters, Tiger imports, kids wheels ereplacementparts are some sites that might have new ones as well. Also you could post in the wanted section and see if any members here have a set for sale 8-)
By mtran1978
#125913
Not the news I was looking for but thanks. If I get some new tires is there a way to prevent this or make them last longer?
Thanks
By MattyGNC
#125915
They will still wear down. I go through a bunch myself, one of the downfalls of modifying a power wheels. You could do a ESC setup that would ease takeoff and keep it from sliding around when you let off the gas making them last a little longer than normal.
By taz11
#125918
You may be able to swap to some tires that have a less aggressive tread. I'm not familiar with the lil dune racer. What are the dimensions of the wheel and axle and what does the wheel driver look like? I may have tons of tires for you super cheap if the size is right.
By taz11
#125949
How long is the axle between the gearbox and the wheel nut? (or how wide is the wheel/ driver assembly) Is it 7/16 diameter?
By taz11
#125988
#17.
I Have a ton of Lil jeep wheels. I'm hoping they will fit. They would look different but at $1 each plus shipping you can burn through them all day long. The older style tires tend to be a little thicker. If they fit and you are interested I could send you a whole box.
By taz11
#126011
My biggest concern is the back spacing. Not sure if they would rub. Going by your pics it looks like you have plenty of room. These use different drivers but they will match the gearbox the same way. I'll get you some pics.
The tires are about 10-1/2 inches tall with the factory traction strip and 10 1/4 without it.
By taz11
#126014
I should have what you need. There are 2 styles. a short and a long. The long will assure that you have enough clearance but the axle may not be long enough. You need to measure your existing set up to be sure. Measure the axle from the gear box driver (base of the slots) to the end of the axle. That will tell us if they will fit or not.
By taz11
#126018
The centers are just stickers (most are peeling) Some yellow, some grey, some have been painted silver.
Many wheels, some with traction band and some without.
By taz11
#126349
With the short driver they are 3-5/8 and with the long driver they are 4-3/4. If you want the wider ones you can replace the axle with some 7/16 rod from a hardware store.....or I can send you an axle out of a 2 seat jeep. You'll have to cut it down. Shipping to Texas is scary :shock: Let me know how many you would be interested in and I'll see what I can do. Let me know if you prefer traction bands or without.
By taz11
#126363
I think you can use the short driver, I'm just not 100% positive. I'll get you a quote on 6 tires. Traction bands or not? Zip code?
By taz11
#126392
6 tires with traction bands (you can remove them if it suits you better) and good wheel stickers. $6
2 wheel drivers and 2 wheel bushings $3
Shipping standard post. $24.
Total $33
By rickmess13
#147304
I have the same issue, my rear tire split on my lil dune racer. I am looking to get some spares but am having no luck finding any online. Can anyone help or provide alternative options that would work?
Hi all I’m new here this might of been cover[…]
Quick and easy swap to 12v. Just did my nephews. N[…]
Final drive gears
Anyone know if the final drive gears are interchan[…]
Just checking in on my issues with this particular[…]
