By hrmax
#137032
Has anyone tried using FlexSeal, or another liquid rubber product, on Power Wheels tires for improved traction instead of traction bands? I saw that ML Toys has a traction spray so I'm assuming it's similar to FlexSeal but just more expensive.
By Tehvipir
#137110
We did that after the conversion to 18v. I wrapped the tires in duct tape to fill in the holes and went through a boutlet of flex seal. All it did was leave black steaks around the driveway and was off in minutes.
By Sedzy
#137350
Anything sprayed on will be quickly worn off by use.
The closest thing that MAY work, is plasti-dip in the brush on can. I've used it at work, and it does dry to a pretty hard rubber finish. Smells like gasoline when its wet though.
That would be the only thing I can think of that might do the trick, but even then, I don't think it'd last long. Especially on pavement.
Make sure you do a good course sanding, and get the layers around all the corners so it is less likely to sheer off in a sheet.
Did you figure out why you where blowing motors? […]
I don't own any PEGs so I can't give you a ready a[…]
Solar Panels?
If i have a 12V/20W solar panel with a 9.5Ah 12V P[…]
