By Roadmonkeytj
#141297
So for threw a 18v drill battery in the red Silverado just for the hell of it to see what the oldest would do.  Checked the voltage before the ride .... 20.1vdc ... Installed the high speed lock out screw.
Rigged up the wires rather crudely fashioned with no connector and a rubber insulator to hold it in place against the terminal (red one has no pw connector).
The boy loved the speed ... I was doing a fast walk beside him.  He's still not really steering and laughs when he hits immovable objects such as the gate or trees since now it sends dirt flying doing a burnout.  But I noticed something .... It has negative camber in the rear and front and has a slight pull to the right from a toe issue.  So has anyone had to fix rear sag before? Do I just install a spreader bar in between the gearbox mounts to push the body out then install the boxes back over it?   I know how to go about the front but haven't really seen anybody deal with the rear.
#141310
Axle is likely bent. You could replace it, try to straighten it, or turn it 180 degrees so it has positive camber then drill it and pin it so it doesn't rotate. Replacement is the only longer lasting solution though
By Roadmonkeytj
#141334
toycrusher wrote:Axle is likely bent. You could replace it, try to straighten it, or turn it 180 degrees so it has positive camber then drill it and pin it so it doesn't rotate. Replacement is the only longer lasting solution though
Since a N.O.S. axle is pretty well out of the question is there a certain bar stock that preforms better than others?
#141339
That's an excellent question... any metallurgists on the forums?
#141348
On that model it also helps to install a wheel bushing in the back side of the wheel , inside the wheel driver. The wheel drivers fit loose and allow for extra slop.
By Roadmonkeytj
#141357
taz11 wrote:On that model it also helps to install a wheel bushing in the back side of the wheel , inside the wheel driver. The wheel drivers fit loose and allow for extra slop.
I'm assuming a sealed ball bearing unit jb'd in place? I know someone did that on here. Or are you referring to the glorified washer I've seen in a couple?
"Best" Choice JEEP
I'm not familiar with the brand but the symptoms p[…]
Yes, you should have matching motors/gearboxes in […]
Ok. So I went with new gear boxes. Titan 775s with[…]
just wanted to share this upgrade mustang 2017 sma[…]
