By tazman6789
#141863
I recently got my hands on an old grave digger power wheel. The back tires have seen better days, what's everyone doing for replacement? I can only find sets of 4 for $115 not looking to spend all that. Any other options out there?
By Suburbancharlie77
#141868
Honestly no, I don't know. It came that way. But the wheel drivers are generically all the same, but instead of the 3 piece setup grave digger came with, would just be a wheel and hubcap. Due to width you may have some solid bar hanging out past the hubcaps??? Could just cut that after you have wheels on. I don't know if silverado parts are available tho. I do know hoods aren't!
Realistically any power wheels jeep wheel will work, you'll just loose a bit of top end. 18V more than makes up for it ;-)
Cruisin McQueen (nz)
NICE ... that is sweet.
