By Z7What
#143830
I havent seen anyone suggest this so here is a idea i just thought about. Has anyone purchased something like this and screwed them into the tires to make them grip better?
Not sure why the link isnt working but look up
"Set of 50 Rubber Bumper Feet 1/2" Width * 1/4" Height + Screws & Metal Washers Built-In" on Amazon.
I would think a pack or two of these would put plenty of rubber on the ground and make for a great traction mod?
Wayne
#143844
Traction sounds great on paper but it carries some heavy side effects. Increasing traction from the wheel to the ground transfers forces directly to the plastic gears inside the gearboxes. From experience, they aren't all that strong
By Z7What
#143891
Thanks for the info, has someone found a easy way to soften the ride that the hard plastic tires cause?
Wayne
#143897
A soft start ESC with soft braking can prolong gearbox life if you do decide to put traction bands on the tires. Another idea is a seat cushion. I did a couple of those for a couple of my kids rides.
By rebelleader
#143899
toycrusher wrote:A soft start ESC with soft braking can prolong gearbox life if you do decide to put traction bands on the tires. Another idea is a seat cushion. I did a couple of those for a couple of my kids rides.
I would be curious to see what you did.
#143905
Here is one of them viewtopic.php?f=19&t=13239
Custom Wheels question
