By Bigmac41288b
#144189
Are you thinking of something like this?
http://gokartsusa.com/Minibike-Sprocket ... ake-2.aspx
I'm not sure if that's what you originally intended but it might work. That's just the first one I found, might be cheaper elsewhere.
By Dasler
#144193
thank you,
I am just wondering how easy would be to attach to cheaper wheels without misalignment and a lot of wobble.
also what would be a good size teeth and size diameter sprocket to start around to achieve around 10mph top speed.
By Lecharbo
#145422
Im in the same boat but in Canada which is costing me an arm and a leg. Original new wheels would cost me about 150 usd to get them here. Just nuts. Ill do my best to find a solution. I know this was written a while back so hopefully you found a solution since.
Cruisin McQueen (nz)
NICE ... that is sweet.
PW Dune Racer
