#145474
Just got this machine second hand for 50 bucks and so far very impressed.
Needed some work (switch board,shifter,gas pedal and all new tires)
So I spent a few bucks and got maybe 3hrs of use before the rear tire split rite in the middle. Not doing anything crazy with it, no curb jumping or over loading, just my 40 pound daughter and her 30lb friend.
Hopefully perego will send me a replacement for free.
Is this a common problem even with a stock machine,it is pretty powerful and seems very well built,just can't believe the tires could be such poor quality.cand anyone recommend an upgrade? Don't wanna go crazy with changing a bunch stuff by trying to go with a full rubber tire.I totally understand that the tires slip and don't have much traction for a reason and I'm fine with that , It would just be nice not to have them split apart so soon! Maybe the gator tires are more heavy duty,or the Gracho ones?
Or do I just need to keep 2 or 3 pairs on hand like NASCAR!
Sorry for rambling on, me and daughter are really getting into this thing. Any suggestions would be greatly appreciated .
Thanks
Relay parasitic drain?
Upgrading Gator
