By MustangGTFanatic
#145510
Hi I'm new here and was doing a project for my step daughter repainting a 12v lightning mcqueen and was curious do the wheels like the rim center part in the middle of the tire is that universal and will go on any of the tires? Also would different tires fit on the car such as tires from a jeep power wheels?
#145514
Jeep wheels will probably require a fair amount of trimming. Mustang wheels may fit? The center axle on most is the same 7/16 bar, so for that, any should fit. But axle length and wheel width does vary, Harley's and a few others have some good shims and spacers, but I'm not sure how much you can fit in the McQueen you have, and still steer? Is yours 6 or 12 volts?
newbie with wheels
pictures
