#145913
Hello!
I have a cheaper car for my kids i i would like tips on how you can make realistic steering with increased turn rate? Cuz the standard steering sucks. Should mention its RC too.
Thanks. :D
"right click on image and choose open in new tab" Works best!
#146225
It sounds familiar to me. It's a Chinese model similar to my ford ranger wildtrak. To increase the radius of the steering, you must sand the points of the steering that serve to stop.
With that it gets more opening in the direction. If you need it to rotate faster, I'm afraid it will not be possible, since the steering engine can not be replaced with a more powerful one without changing the electronic control unit.
Chain Drive Dune Racer Prep
Are you going to put a bearing or bushing inside t[…]
Noob question Peg Perego,
I love it so much If it is useful and knowledgeabl[…]
You are my helper I want to thank you so much for […]
Figured I should probably post a picture of it all[…]
