#146347
Greeting everyone! I wanted to share what I've done so far to my son's PW.
I noticed that when my 80lbs nephew rides with him, the front wheels would camber, so I made a cut to house the extra support.
Add description
PW Cut for Extra Support.jpg (42.59 KiB) Viewed 935 times
It's strange that after the cut, it seemed that it was meant to have the extra support. Here's what it looked like afterwards.
Add description
PW Extra Support.jpg (55.69 KiB) Viewed 935 times
I discovered that the galvanized steel that I used wasn't stiff enough to support the top, so I switched locations with the original support, and also I sandwiched a thrust bearning for easier steering.
Add description
Thust bearing01.jpg (29.95 KiB) Viewed 935 times
I might weld a T bar later to replace the steering knuckles and place the support on top and bottom ends.
I cut up a bicycle tire and riveted them on the rear wheels, used a single 700 X 40C tire from my hybrid bike, it had plenty of rubber. Still, I stretched it a bit to make the tire profile low.
Add description
PW Rubber tire.jpg (60.55 KiB) Viewed 935 times
I hate the grinding noise that the plastic wheels make on pavement when it's running over tiny pebbles, so I'll try spraying the front tires with Flex Seal, and hope to reduce that noise, then maybe I'll do the same for the rear tires. :D :D :D
My son's only four, turning five in September, so I hope that he'd be able to ride this car for a few more years.
