#147222
Here are some good links:
Factory axle is 7/16" and most of these pneumatic wheels have a 5/8" bore. As suggested below you can get a piece of 1/2 PEX pipe which has a 5/8" OD and is very close to 7/16". I'm currently waiting on some 7/16" to 5/8" flange bushing/bearings to tighten up the tolerances.
http://www.saltydog.com/powerwheels/
viewtopic.php?t=10260
Custom Wheels question
