By splitbux
#147930
IMG_0693 (1).JPG (74.18 KiB) Viewed 743 times
weld Point where handlebars connect to steering column has broke. Is there an epoxy strong enough to fix this.
By Hammer-fm
#147958
No, Epoxy won't hold up on something like that -- there's too much force on a very small radius.
newbie with wheels
pictures
