By Lele
#148892
Hi all,
as i described in the subject i am here to ask you how to remove wheels because after removing the ferrari logo caps in the center of the wheel there isn'n any tipe of screws and trying to pull the rounded head rivet seems to be difficult and dangerous for the wheel itself (as you can see in attached images the bearing is visibile under the rivet)...
So what's to do?
I really appreciate any help...
Emanuele
#148895
What is the manufacturer/brand name? It is probably a pushnut. The manufacturers website may have a parts list. Pushnuts are not made to be re-used and often get destroyed when trying to remove. There is a removal tool available but a little patience and a large set of slip joint pliers will do the trick.
By Lele
#148928
I've checked the manufacturer website but there is no evidence of complete part list..
So i wanna ask you if is possible to renew the steel bar with threading it at the end to screw with an exagonal (normal) nut...
