#149800
Hi,
i have a problem on my wheels on my polaris 800. It looks that from the friction they are getting so hot that the center core melts and then they loose contact to the drive hub. Is there a easy to do mod to avoid this, i want to ride my toy again but can't because of this.
#150015
Unfortunately I don't know anything about the PEG vehicles, but I admire your problem :oops:.
#150042
MightyMaxx wrote: Mon Sep 10, 2018 2:24 pm Hi,
Never had that happen before. Perhaps try sanding the ends of the axles a bit and installing the new caps with a little grease?
Which gear box I need ?
I have googled gearbox power wheels but only found[…]
I haven't posted in a while but wanted to give a l[…]
Volts/ current regulator
Many thanks. I had a go at this earlier today, how[…]
Need a help
Hi! This is my first build on upgrading my kids N[…]
