#150965
First post and tried to do a search but couldn’t find anything- so I apologize up front of this has already been posted.
Trying to do a wheel mod on my little girls Peg Perego 12 volt RZR 900. We bout it last year so it’s the model number IGOD0066.
I wanted to check and see if anyone knew if the inner hub of the rear wheels from the 24V will fit the gear box for the 12V. I know it won’t fit the wheels of the 12V, but just needing to know if it will fit the “cross” part of it. The model number for the inner hub of the 24V is SPST8931N.
The inner hub that is used on the 12 volt is much wider and wouldn’t provide anyway to have a bolt on it for it to be secured to the wheel. The 24V inner hub is more of a cone shape and has an inch or 2 smaller flange that would provide a spot for it to be attached.
12V wheel gear
The inner hub for the 24V
Any help would be greatly appreciated and thanks in advance.
-Josh
Inner hub of 12V
Hello all. My Name is Sean. We reside in the Appal[…]
Blue Jeep Hurricane Part Out
I would like to purchase the radio, even in non wo[…]
The breaker could be getting weak. If there are no[…]
