#141708
So all total, scrapping the donor to driving the lifted unit, how much time would you say this takes? And how stable is it, say running some aggressive tread tires? Did you ever run 18V or too squirrely?
Just curious if this is weekend or week long? I have a solution for some sunfaded heeps now!
#141718
Suburbancharlie77 wrote:So all total, scrapping the donor to driving the lifted unit, how much time would you say this takes? And how stable is it, say running some aggressive tread tires? Did you ever run 18V or too squirrely?
Rock solid afternoon or a weekend if you take too many breaks for "refreshments"... ;)
Cordless Tools
I have a question about electric trimmers. I have […]
Need front end parts for the jeep hurricane, prima[…]
Wired, I have gained a lot of information from th[…]
