By sailinghickey
#144210
To all ye who read this, greetings! I have recently come into a freebie Peg Perego pedal drive front end loader that has seen better days. I would like to restore/convert it and even upgrade some of its features, such as lighting and hinge points. It may be a while before I get started as I have an obscene number of projects before it. If y'all would be kind enough to post links to other projects doing similar work, I would greatly appreciate it. Thanks.
#144221
It's only the housings that are different: small a[…]
Need wiring help
A potentiometer is a three-terminal resistor with […]
Motion Trendz Buzz Lightyear Car
So has anyone found a good place to find these gea[…]
Exploding Controllers
I would double-check the battery/wiring polarity -[…]
