#144538
Hey fellas, the 12v battery died in the Peg Pergo gator and I picked up a 96v (8x 12v) cell for a APC UPS. I rewired it in a parallel series for 24V and rigged it up in the bed of the Gator. She ran like hell for a bit then got exhausted from the weight, I presume. (Probably 70+lbs over the rear wheels)
I picked up two 775 Mabuchis rated at 18V, 19K RPM and have a couple questions that I am hoping you guys can help with.
1. Will any 5mm 32p Pinon work, or do I have to find a 10T? (really hard to locate) Ideally I'd like to go down a tooth or two to give more lowend.
2. What is the trick to mesh up the 775 to the stock gear box? The face bolts are a little wider set.
Lastly a bonus question: I am gettting 25.6ish Volts off the battery bank, but at the motor hookups its lower. Is the pedal or something in between knocking down the voltage?
Thanks in Advance!
Newbie in the UK
Interesting. That looks like an older (red painted[…]
Converted from 6v to 12v. Added ESC with twist th[…]
Search around the website. there is all kinds of p[…]
Your gonna need flotation tires in soft sand. The […]
