By Rshep
#148740
Ok guys just as a recap since it was so long ago I have a Rastar Bentley GT convertible that only goes in reverse. The shifter switch has 3 positions hi, lo, and reverse.
When the shifter is in forward I can hear the motors making a high pitch buzzing sound trying to spin but get no movement from the car.
I have taken the dish and the shifter apart and all the connections seem clean and I even put dielectric grease on the ones I could by the battery and the motors.
My first thought was the shifter was bad but the car is also r/c and when I put it in r/c mode so the switch doesn’t mover or matter where it is the car still only goes in reverse.
I have verified the motors are getting power in reverse as well as in forward mode.
Any ideas?
By Rshep
#148748
So I purchased two new motors thinking it had to be a motor problem. The new motors still only go in reverse. I’m stumped. If I’m getting 12v to the motors in reverse as well as forward idk how I only have reverse
http://forum.modifiedpowerwheels.com/viewtopic.php[…]
Aloha, to whom it may concern: After doing a litt[…]
