#150957
Wasn’t too difficult to install. Had to cut the plastic that went around the factory 550 motors to make room, and drill out mounting holes for bigger screws and some washers. only thing im trying to figure out is at 100% on speed controller from eastcoastpowerup esc module it goes a couple feet then completely dies. After a few seconds it turns back on. With the factory 550 motors this did not happen. Here is a link to jeep at 50% on speed controller
Can check my channel for other vids of the jeep
Hello all. My Name is Sean. We reside in the Appal[…]
Blue Jeep Hurricane Part Out
I would like to purchase the radio, even in non wo[…]
