By enigmatizing
#83520
Hi Everyone,
Two weeks ago I replaced the dead 6v battery with a 12v 12AH battery in my son's Motion Trendz Buzz Lightyear Car. It definitely increased the speed and run time for the car. The problem is that now a couple weeks later and 3 charges later it seems that the 6v motor has died. Is there a 12v motor I can replace the stock one with? Or I have read in some of the post where you can install (2) 6V motors and gearboxes into these. Would those also crap out with the 12V battery? Any help is greatly appreciated.
By bruces_eviltwin
#83557
if you go with 2 motors at 12 volts it evens out at 6 volts each and that means no more pushing a stuck car!:D I have a brand new gearbox and motor if you need$15 plus shipping
By enigmatizing
#83560
Thanks for the reply,
Does that also mean it would go back to only 2.5MPH? Also, I don't see a left/right motor designation anywhere. The stock motor in on the right/passenger rear tire. Would I need to do anything special to the wiring so that both motors spin forward/reverse together. I may take you up on your offer, once I make a decision on this.
By bruces_eviltwin
#83561
wire the motors in series with 1 motor connected backwards, you may need to replace wires with heavier gauge wires. should give you a slight speed increase
By enigmatizing
#83565
Thanks for the info,
What about going with something like the HPI GT550 14.4V motor? Would that fit into the stock gear box? Or could I get new gearbox's with the new motor that will attach to the tire?
By bruces_eviltwin
#83571
im not sure the gear box would hold up to a higher rpm motor. I dont have any expierience modding these other than lights. I dont sell performance modded stuff and my kids are too big for em. I got a few of these as store rejects to play with and ended up selling em to friends for xmas gifts I just have the 1 left with a busted body that idont feel right selling.
By enigmatizing
#83699
Hi guys,
Quick update. I picked up a Titan 550 14.4v 21T at the local hobby store today. It the same size as the stock 6v 540 in the Motion Trendz Buzz Lightyear Car. So I am going to install it this evening and see if it works. If it does I may pickup another gearbox and a 2nd Titan 550 14.4V 21t and really speed this little car up.
By bruces_eviltwin
#83706
you may need the second drive wheel to reduce the spinout effect!
By enigmatizing
#83725
Good news! The Motion Trendz Buzz Lightyear Car is back on the road. The Titan 550 works great. It has even given car more speed than just the 12v upgrade. The drive wheel just spins for 5-10 seconds before it gets enough traction to start moving the car. With just the 12v upgrade the car was still fairly slow in the grass, but now with the 12v battery and the 14.4v Titan 550 is zooms right along in the grass. Temped to add a second gearbox and motor, but its plenty fast for my 2.5 year old for now. Thanks for the help.
By bruces_eviltwin
#83728
i still have spare wheels also! you may need em with all that spinning :D
By bruces_eviltwin
#88615
still need wheels? sorry i missed you somehow! I have a near complete brand new car with a busted body
By Kittyberg
#143996
Hi guys,
Im a little late to the party. I just bought this buzz lightyear car used off of craigslist. I have bought a new charger and it seems that the battery is dead. Can someone pretty please direct me to a link to buy compatible replacement battery? Im having a TOUGH time finding one. I have seen one on sears.com but it does not look like the Neata nt6-5 (6v5.oah/20hr) that is currently in Buzz car. THANKS IN ADVANCE- meery merry :)
By Bigmac41288b
#144001
Really it all depends on the dimensions of the space you have to put a battery. As long as it's 6v it will work as designed. More "ah" (amp hour) = more runtime. 4-5 ah battery is pretty small and has limited runtime in my opinion. If that is all that will fit then it will have to do. If you can manage to fit something larger it may be worth the few extra bucks to extend the runtime.
This is one that should be comparable to your original battery:
It list the dimensions of the battery in the description so just make sure the size is close, unless you want to modify to something larger.
By debmar15
#145833
Would love to upgrade on the volts but just looking at this moment to get a battery.. The battery in the buzz lightyear has the fuse at the top that is wired... Can I just buy the recommended compatible battery? when I see what is recommended I don't see the wires and fuse do I need the fuse still? Do I rip this old battery apart ugh I know I'm just a gramma but I want to fix this without going the 40 dollar battery route. Can someone point me to a youtube or diagram on how to get the new battery to work.. in this car I read in a previous post below.. This is one that should be comparable to your original battery: www.amazon.com/6V-5Ah-SLA-Rechargeable- ... B00MYL8OQU this is the original battery 6v50ah20hr thanks for any help
By Dddthorp
#148732
Kittyberg wrote:Hi guys,
In reply, I got one for $15 without battery at goodwill today, went to batteries plus, and got the rayovac RAYA6-14T1 it has more Mah, instead of cutting the wires to void warranty to battery, I cut the factory plug off, and added my own choice male female set of connections that would Y and have dual connections when soldered, which worked great. Now I plan on adding a 25 watt solar panel on two 1/2" pvc poles at corners for heat/shade and maybe a usb to charge her tablet. I am confident I will choose upgrades and will continue to update here in the
By Dddthorp
#148734
debmar15 wrote:Would love to upgrade on the volts but just looking at this moment to get a battery.. The battery in the buzz lightyear has the fuse at the top that is wired... Can I just buy the recommended compatible battery? when I see what is recommended I don't see the wires and fuse do I need the fuse still? Do I rip this old battery apart ugh I know I'm just a gramma but I want to fix this without going the 40 dollar battery route. Can someone point me to a youtube or diagram on how to get the new battery to work.. in this car I read in a previous post below.. This is one that should be comparable to your original battery: http://www.amazon.com/6V-5Ah-SLA-Rechargeable- ... B00MYL8OQU this is the original battery 6v50ah20hr thanks for any help
In reply, I got one for $15 without battery at goodwill today, went to batteries plus, and got the rayovac RAYA6-14T1 it has more Mah, instead of cutting the wires to void warranty to battery, I cut the factory plug off old Buzz lightyear instead, and added my own choice male/female set of connections that would Y and have dual connections with the 6v charger I got brand new with the battery at Batteries+Bulbs and cut the plug off charger too, adding matching male/female adapters, BE SURE TO HAVE 30A green fuse in line then soldered, which works great. Now I plan on adding a 25 watt solar panel (or two) on two 1/2" pvc poles at corners for heat/shade and maybe a usb to charge her tablet. I am confident I will choose upgrades and will continue to update here in the
By JasMull1230
#149025
So has anyone found a good place to find these gear boxes, wanted to add another drive wheel to the car, or should i just upgrade from a 6v to a 12v motor on the stock 6v battery?
PW Escalade starts,slow,stops
Huffy Lightning Mcqueen
Kids motorz Chevy bel air
