By alan566
#92745
Hi,
I just bought this used and it only pulls one wheel and no low or reverse. i read the reviews at wally word and learned this is common problem. anyway i checked it out and the problem is a little tab is on the outside of the left motor. the tab is inline with the black wire and is clamped on the motor with a hose clamp. i think its a capacitor but just guessing. anyway if i bypass it the motor runs.
Is it ok to bypass it and let my boy ride it? If not where can i get one? i have only tested it off the atv and would like some input before i put it back together. thanks, alan
By taz11
#92751
Hose clamp on the motor? :? :? :? :? :?
Can you post a pic? Doesn't sound stock, sounds like an attempted repair.
By alan566
#92755
it looks stock. but i agree about the hose clamp doesn't sound stock. the solider is perfect and it looked better before i took the clamp off then put it back.
and i installed the blue trailer clamp as a bypass. oh yea i haven't found out who makes these either, anyone know? i don't think its a power wheels.
By alan566
#92756
i think I'm going to put it back together now and see what happens. please give me some input about this motor and that tab on the side if you can. this thing is a 24v but its top speed is only 5mph so i am gonna need some help here to get some speed out of it. thanks, alan
By taz11
#92760
Um......YIKES!
I'm not familiar with that vehicle but that is definitely not stock.
My thought is to remove all that stuff and connect the red wire right to the motor tab. I suspect it is some type of thermal switch that went bad and somebody tried to bypass it. Hose clamps are not OE! :lol: :lol: (usually)
By alan566
#92778
It was connected with the tab, it wouldn't work. I used the blue connector to connect the two wires. It works fine now in low or reverse but blows the fuse in high. I now think your right and it is a thermal switch. On the side of the atv it says it has a thermal overload that lasts for a few seconds and then the motor resumes. I know it looks funny but I think it came that way. It's a motion trendz. Where can I get a motor from?
By alan566
#92781
I sent custermer service an
Email so I'm waiting to here from them and see what they say. But if anyone knows a place to get faster motors then I would probably go that route. I'm checking out other forums too right now.
By chopo1990
#92785
Have u check the wiring? Does it have a control board? U might be able used a aftermarket motors and run 18v or 24v with a ESC
U will need to find what series motor u have and teeth
and pitch count
I don't think u can buy 24v motor
By alan566
#92802
Thanks, the wires are good, I checked continuity and everything was the same with both motor leads until I came to that tab. not sure about the board. I will pull the motor back out and try to get some info. Thanks again for the help.
By alan566
#92842
not sure what that was so i took a pic of it. lol the 2nd pic is the tab on the motor.
I checked the voltage going to the motors and it was 26.2 going to both motors in high gear and mashing the accelerator. I need to find one replacement or two aftermarket motors that with speed it up. still waiting on cs from motion trendz. it was made in 8-15-2012 so its not old but i didn't get it new so i have no receipt so expect cs will at least offer a replacement motor to buy. any help on finding motors would be great. If just replacing the motor is my only option then any suggestions on next step to get more speed? thanks for all the help so far!!!
By taz11
#92853
What is the bolt spacing and shaft diameter?
14000rpm at 24 v///// :? :? :? :? :? :? :? Needs help!!!! :lol: :lol: :lol: :lol: :roll: :roll: :roll:
By sea_stork
#92873
I saw those new 24v Grizzly's at China mart just before Christmas last year. Made by Motiontrendz, so the hose clamps may be stock it it has them on both sides.
By alan566
#93204
Thanks, I already bypassed it and it keep blowing the battery fuse. And after a few mins that motor quit pulling all together.
The email back from customer service just told me to call them and they would help. So I called them this morning and they agreed the motor was gone. So I asked about having further trouble with the motor and they said they will through in another motor if that will help. Because I didn't have a receipt they could give me the motors but I would need to pay shipping. I was very impressed! I fully expected to pay for everything. I pulled the the motor and gear box and put the wheel back on and it runs great in h
By chopo1990
#93715
alan566 wrote:Got the new motor and gear box, the worm came on the new motor. It works perfect now. About speeding it up, could I just add voltage? If so how can I go 36v?
Add a 6v in series, if u want to run 36v use a ESC setup
#104504
OP, do you by any chance have the contact information for the customer service for your grizzly?
I'm in the same predicament, blown motors... can't seem to find anything online that resembles this motor.
Thanks!
By joantrski
#114782
Does anyone happen to have the info to contact the manufacturer to get a new motor or whatever we need. We have the same problem (low and reverse doesn't work and one wheel spin on high). My son got this as a Christmas present and it's broken in less than 24 hours.
How is the customer service? Praying for fast turn around. we're all quite disappointed.
By mrlonney
#118034
Did anyone get this problem resolved, I have the same issue with my daughters quad, first day and the motors burned out, any way to replace them, or upgrade them to something different ?
By amandam
#134811
If anyone sees this and has any idea where I can order a replacement motor like the one talked about in the post I would greatly appreciate it! My son's power wheels is having the same issue described in the post exactly! Printed on the motor is, "24V14000RPM." I have spent hours on google and calling all of the repair shops but no luck with a replacement. Any advice would be great! Thanks for you time! :)
By FLoHIO117
#146072
I just inherited this quad from a friend. Same issue with red side motor. Has anyone found a motor I could just replace both with? I'd like to upgrade the speed. Stock Motors say 24v 14000rpm on them.
By Driver
#147535
I see this is a old post but for anyone needing to know where to get the parts. I finally found the motors and gear boxes at kidswheels.com
Part number for motor only is
Peg Perego 24V Motor SAGI9987
I also bought gearbox and motor together but didn't save that number.
Razor quad
Question about a razor quad I'm sure someone has s[…]
Please let me know if K1w1ed doesn’t pick this up.[…]
7R transplant into a 7 Gearbox
Not totally clear on your question. You can direct[…]
Need some guidance 6v f150
http://i28.photobucket.com/albums/c2[…]
