#145739
Hi Everyone,
Bought a used PW escalade. Battery was shot so ended up going with a 18v battery setup from 12vCustoms. If I want to upgrade the gearbox and battery what do people recommend?
Thanks T
#145752
Yes, Stage II has hardened steel pinion and first gears. You shouldn't need to do the rest in metal. They handle up to 24v no problem when driven properly and with stock tires. Stage II has a 1 month warranty on nylon gears and lifetime on steel. We also sell all of the stock gears individually on the website if you have a 7R gearbox or Staged kit.
12v and it’s used
hello I was wrencher on the old site. I am selling[…]
Newbie with need of help
Hi, Picked up an old gator and been trying to get[…]
Two things I think could be happening: #1: The s[…]
