#146286
I recently got a dune racer for my daughter and it was working perfectly for about 15 minutes and then it stopped working. After researching the issue I found that the high speed still works. I bought a new shifter and a new pedal switch but the problem still persists. I see a lot of responses saying to clean the switches. I'll give that a try. Any other suggestions to try? Thanks!
New here but not to the car scene
Hey guys! We have some ride on cars and one Merce[…]
http://www.amazon.com/dp/B00A82A3RK/ref=cm_sw_r_cp[…]
French people ??
Is there some french people here ? I have a lot o[…]
Blown fuse in high gear
I have a 24v monster jam grave digger with the mlt[…]
