#146288
I was gonna do a traxxas motor upgrade but after reading the sticky about motors and reading reviews I think I will be going with these guys the Duratrax 550 Size Motor
Now onto my questions!
Question one, In my reviews I heard that some fabrication needed to be done in order to get the pinion to set right in a power wheels gear box. I myself have number 7 GBs @ 12 volts. I was wondering if I could just JB weld on a pinon and if you pros out there think that would hold? If not thats crazy! I Jb welded some cracked heads and they heald for 5 years but failed after I smashed a 10 pointer @ 70 MPH. To be honest though the whole engine failed at that point not just the heads lol.
Question 2. I do not want to do an ESC at this time however, I was wondering if there was a way to soften take off and stopping so it doesnt jerk so bad.
I have dug into the forums and have seens this question asked but a lot of responses had pictures with dead links.
Any info would be greatly appreciated!
-Check out my project page titled Fire Rescue Jeep!
escalade headlights
