By Zeez
#146303
Can someone please point me in the right direction on where to get a replacement motor for my dune racer? I've tried searching based on the numbe on the motor, 00968-9015, but I can't seem to find much on the internet for that model number.
Zack
#146305
Hey Zack,
Here is an older PDF of motor specs (good to have for comparing motors):
http://team-paragon.org/wp-content/uplo ... rs-571.pdf
Here is a link to a supplier of 9015 motors. I think it's the motor you're inquiring about:
https://www.andymark.com/Motor-p/am-0912.htm
You can also post an ad in the wanted section on this site. Hope this helps.
24V Gator project
Wow great replies I was looking for this info.
Hi all, First thank you in advance for the inte[…]
Is there a walk thru how to do post for a beginner[…]
ESC can save the wear and tear on gearboxes?
