By Phil813
#146328
Does any one know where to buy gears for the Blue F150. It appears the the final gear connecting the wheel is worn an sliping.
Thanks for the help!
#146330
Wanted section. Post the model number and your zip code. If you have pics it wouldn't hurt either.
By Phil813
#146418
I was able to get replacement gears from ML Toys and Mike there has been great to work with. Last night I put everything back together and my son ran the truck for 10-15 minuets under 12v and no issues. I put the 2nd battery in for 24v and within 15 minuets he had already started to strip the 3rd & 4th gears. Is there another option out there for stronger/aluminum gears? My son weights around 65lbs and it seam to only strip out on the drivers side. I wouldn't think the weight is the issue. The axle was hot when I broke the truck down to remove the motor. I also checked to make sure the axle was not bent. I imagine if I try to get something made local the cost will be ridiculous. Any help would be appreciated.
The model is CDF53 and are local to 21108.
Corevette Motor
so much info on this site, but I can't keep it all[…]
Great project! If you click my projects link in m[…]
Unfortunately you are better off with something li[…]
I too would recommend east coast power ups or CJB'[…]
