By Colemantk
#146332
Anyone know which tires I can use to replace stock( discontinued) I have the 14 inch size. Please help !!!!! Also I wouldn't be upset switching the hubcaps. I broke one while taking apart :( My 4 yr old son was helping. !!! Any help would be so great thanks.
By KVP
#147194
I may have the wheels you need. I have a set of 4 that I bought for a project but will not be using them. Their diameter is roughly 13.5 inches and will fit the
AfterShock jeep that I have. I see by another post that you live in the Grand Rapids, Michigan area. I do as well. If I can help you out, let me know. My grandkids have moved out of state and I'm willing to give my Power Wheels and parts to someone who will use them to make their children smile.
Circuit breaker popping
