#146508
Assuming the Avigo is a 550-size motor you won't be able to reuse the pinion -- 550 motors have a 3mm drive shaft, where the 775 have a 5mm drive shaft. If you go to a pinion gear with more teeth then the motor mounting position will have to be changed. Amazon sells 9T 32dp pinions for 775-series, but I haven't seen any 8 tooth ones anywhere.
I saw a picture of the Avigo gearbox in one of the other posts but it didn't have much detail. It almost look like it may have had a planetary reduction box on it (like a drill) -- which would be not accept a different size gear. .
I think you'd want to first measure the existing motor to verify what the can size is, measure the pinion to determine whether it's 32dp, 24dp, 0.8mod, 1.0mod, etc., then you can determine whether a 7-series is even an option.
#146514
You can look up 5 and 7--series motors on a number of websites and compare dimensions.
This is a Mabuchi datasheet for some 550 motors:
http://www.robotstorehk.com/rs_550pcvc.pdf
There are a lot of different variants: 5-series (550, 545, 540) and 7-series (735, 755, 775). The "7" designation refers to the diameter. The 7-series motors are basically all ~42mm diameter (excluding torque sleeve) and has a M4 thread hole with 29mm spacing, and they all have a 5mm shaft. The 5-series are 35mm diameter, M3 thread @ 25mm spacing, and all have a 3.175mm shaft. The 550 vs. 545 vs. 540 are just different lengths (550 = ~55mm long). Same with 775 vs. 755 vs. 735 -- 755-series motors are about 58mm long. 775 are about 66-68mm long.
Yours looks like a 550 motor, and probably a 32DP (or m0.8) pinion -- though if you can measure the diameter you can verify it's not 48DP, mod0.6 or something else odd. "32DP" is diametrical pitch; theoretically a 32-tooth 32-pitch gear is 1" diameter. A 16-tool 32-pitch gear is 0.50" diameter.
Here's a 775 motor that has a datasheet for comparison (it's low-speed, not a good fit for a ride-on toy, but the case size is standard):
http://www.robotshop.com/en/rs-775-motor-7000rpm-12v-7613oz-in.html#Specifications
By gerlt
#146516
Measured 1.5 inches diameter, and 54 teeth, which comes to 36dp....its entirely possible I miscounted the teeth but I counted twice.
By L.Bain
#147249
I'm hoping you can help me. I have the same car but by Famosa. The Gear box is not available on any website and when I took it apart I see the problem is that the gear that connects the motor to the gearbox is broken. Any ideas how I can get another gear?
You can see the motors here
specs:
Famusa Feber Range Rover Sport
RFC-IEU030805UU0
8008662-80011495-102014
Gear box
Rel.1360 12-6v
IT00091106
Chengfeng Motor 6v dc
A06-5th1014
200017470
480931
Image, the silver 8 tooth gear that is on one motor is missing on the other. This is the part I need. It looks exactly like the motor /gear you have pictured above. Can you tell me the gearbox assembly part number?
I'm looking at that now too. I don't think there i[…]
Circuit breaker popping
