By jwz200
#146743
I have a Jeep Hurricane that has some teeth missing off the larger gear. See attached pictures. The number on this gearbox is 085802. I believe this is a #7 gearbox after doing some research on this forum. Can anyone verify? The motor has 13 tooth gear. Unfortunately I garbage picked this power wheels a few years ago and the serial number sticker was gone missing.
Questions:
Can I get this gear to replace in both gearboxes?
Anyone have a good source to get a complete #7 gearbox with motors?
Can I use a 7r gearbox if I replace both gearboxes and motors?
Thank you
#146745
"Can I get this gear to replace in both gearboxes?"
Yes, you can post an ad in the wanted section here or purchase on Ebay.
"Anyone have a good source to get a complete #7 gearbox with motors?"
Plenty of these around. Again, post an ad in our wanted section and you will likely get more than one response. Shop around.
"Can I use a 7r gearbox if I replace both gearboxes and motors?"
Absolutely.
"Thank you"
No problem. We are here to help.
:D
Hi all, New to the forums and I searched for this[…]
Find new experiences. Just click to see every day.[…]
Have interesting content. I have never seen anythi[…]
For a better solution, you can utilize algicide or[…]
