#146870
Sorry as after searching this has been asked a million times but I am still looking for an answer. My 2014 Perego Gator is 12v, but is not switchable between 12v or 24v, and I am installing the 775 motors in the originals place(with original gear box). I will mod everything to make them fit, but I am trying to fit a aftermarket pinion to match the original. The original is a 10T gear, the the shaft on the 775 is 5mm not the stock 3mm. I can drill and press fit the old gear on but can I use anything aftermarket that will work with the original gearbox? Or does it need to be the exact same as the original? Thank you very much guys. I am going blind from all the searching.
escalade headlights
