By L.Bain
#147252
I need help finding a replacement pinion gear (at least I think that's what it's called). It's the gear that connects the motor to the gearbox assembly. Here is a picture, you will see that one is broken, which is what needs replacing. I swapped them and they work correctly.
link to pic
specs:
Famusa Feber Range Rover Sport
RFC-IEU030805UU0
8008662-80011495-102014
Gear box
Rel.1360 12-6v
IT00091106
Chengfeng Motor 6v dc
A06-5th1014
200017470
480931
Peg Perego Gator
Help. 6 volt not enough.
Gaucho Grande gearboxes
