By lexx0116
#147366
Just got a pair of the banebot 775 18v version yesterday and one of the motors has a couple of the fan fins broken when received. Should I return and get a replacement or this issue won't affect the normal use of the motor. The Rep said it won't affect anything but I just want to make sure.
#147388
I don't know enough about the airflow inside to know how much impact it will really have on cooling.
That said, the factory DID put all of the fins on for a reason. At the least, it will now be slightly out of balance... :lol:
If you have to pay to ship it back, then it's probably not worth t worrying about it. Otherwise I'd press for "like-new" parts...
By lexx0116
#147389
Unfortunately Banebots website stated that I need to pay the return shipping so with that said, I just keep this one. I did notice however that the fan is slanted slightly. Worst case is I buy another pair and keep this pair for backup/spares.
Quick and easy swap to 12v. Just did my nephews. N[…]
Final drive gears
Anyone know if the final drive gears are interchan[…]
