#147826
I have been after the perfect ride on for my kid for a while now. Our property is hilly with trails that are leaf covered. So I added rubber tires, the stock 24v set up (control board) hated the rubber tires so I added the ECPU 1000w controller and now I fried the motors. Is there a direct fit motor that I can add relatively easy? If so, where can I order it? Any help is greatly appreciated, my little one will certainly enjoy it too!
#147833
You will have a hard time finding 700 series motors that will survive long. Here is your only true solution
viewtopic.php?f=19&t=12855&p=130424&hil ... zr#p130424
#147835
Toycrusher, thank you for your response. I am not sure that I have the ability to go to that extent and I cant find some of the parts listed in that thread anyway.
Any thoughts on the Dewault 820 motor? Does the Kershaw designs adapter make it a direct fit for my little boys rzr?
BTW, I took the old motors out last night, the fan in them was completely burned up... OOPS :)
#147837
I'm afraid I don't have any experience on the motor and/or adapter you referenced. I've become very frustrated with stock Peg perego motors lately, pretty much given up on my Rzr and Quad. I'm tempted to run Banebots at 24v but my whole system is wired for 36v and I'm lacking motivation to redo it all.
Date code decoder?
