By spellow
#147929
so much info on this site, but I can't keep it all straight.
I have a corvette, 7R gearboxes, 1 motor burned up at 18V...so looking to replace them...what is a motor I can but, put the 23 tooth pinion on it and run at 18V safely?
is the Titan the new choice?
#147941
I measured the Corvette motors I had at around 19500 RPM at 12V, so you're running around 29k RPM at 18V. A fairly direct match would be these two motors:
http://www.robotshop.com/en/rs-550-moto ... oz-in.html
http://www.robotshop.com/en/banebots-rs ... 00rpm.html
The specs are basically almost the same (one is $2.25 cheaper and has a rear shaft, which won't hurt anything; it also is in stock which is a bonus). Biggest gripe is that the front shaft is fairly short; the factory gear will press on and should be ok, but I haven't used this exact motor. You'll want to use some red loctite or other sleeve retainer and rough up the shaft surface. I'm fairly certain it has a fan based on the model name, but the pictures aren't clear; the Banebots one definitely does.
For 20% more speed (but likely even poorer longevity), you could try the 23000 RPM Nichibo motors from Jameco ($3/ea):
https://www.jameco.com/z/KC3SFN-8021F-7 ... 58540.html
(or their ebay link here: Nichibo Ebay link )
I was happy with their performance with Corvette 23T pinions on a PW Mustang, but only ran it at its rated 12V. Buy 4 and plan on replacing them ;).
Cordless Tools
