By corbette
#148222
Hooked up two 12-volt batteries to my RZR and after awhile, I noticed a cranking/grinding sound coming from the back left wheel. I popped open the case to find that it appears to be the gear box, the motor seems to be just fine. I have a couple questions at this point...
1. If I upgraded to a 24v system, would I need to get the 24 Volt gearbox and motors or can I stay at 12 volt?
2. If I do upgrade to the 24 volt gearbox and motor for the tires, will they just go right back on like the 12 volt parts did?
3. Would I need to upgrade any other parts to go along with the new 24volt batteries?
4. I had a 30amp fuse in there that blew twice, would upping the amps on the fuse resolve this issue?
I'm completely new at all of this and would greatly appreciate all and any help! Thanks!
Nope I never figured out how to get the fork apart[…]
Hello Everyone..
Hi, I am new here. I found this forum while surfi[…]
