By Amtack
#149104
First time modding a power wheels. If I upgrade the motor to a 775 but leave the battery at 12V is it worth it? Or should I upgrade the battery first? Only looking to go to 18V at first, but I don’t want to do too much too quickly. I’ve read doing the battery first can burn out the stock motor.
Thanks in advance!
#149107
Opinions vary but I would start with the voltage increase to 18v with the stock motors. Upgrade as things break.
Low voltage warning
Building a new pool
Lightning McQueen lowered
