By Blues2124
#149603
I was looking at purchasing eastcoastpowerup easy esc or universal kit. I bought 2 new batteries for it and was going to install them underneath the body. My questions will these kits make the gator go faster? If it does that's great. Will these kits destroy the stock gears? Will rubber tires destroy the stock gears? If you have had both kits which one do you like better? Im trying to figure out which kit to buy if any, if I should install rubber tires or not, and if I should install different gears or not. Also I would like to install a light kit and possibly a horn.
Thanks
By thisdave
#149651
Looking at doing the same...
Interested in anyone's input who has used these kits...
Cheers.
By Blues2124
#149693
Does anyone know how to contact eastcoastpowerup? I would like to start this project
By Blues2124
#149695
I have already emailed the website about a month ago. I didn't know if there was a phone number. I didn't know if this was normal or not to wait this long. If so no big deal.
#149698
I haven't personally worked with Wesley but certainly based on other feedback I would not expect a one-month wait. Try PMing him and/or send again?
newbie with wheels
pictures
"Best Choice" Jeep?
Keep the supply voltage to the relays and accessor[…]
