#149614
I found a used Kawasaki Power Wheels on the side of the road and I decided to tinker with it. I believe the gear box is possibly 3A gear box. I was waiting to know if I can get a gear box that will not strip out as easy as this one was already stripped. I have one 12 volt battery as or right now. Is it possible to make this thing slightly faster?
Edit: Image
New Here!
How do you do the lights😯 They are amazing 😉 […]
Peg Perego Magica parts
I have bumpers..
Voltages
Voltage surge is characterized as the unexpected a[…]
