By Cliffsmith4
#151284
I have googled gearbox power wheels but only found the "c" on amazon etc. Gearbox HSA 00968-0502-01 A. But everything I see has the c after the number
#151297
If your gearbox is the one pictured then it's a 7R type gearbox. Those are the newer style. I can't make out which one it is but I can tell you how to figure it out real quick. Just count the number of teeth on the gear attached to the motor. this is the pinion gear and will tell you which replacement you need. 16 teeth equals a 16t 7R motor/gearbox. 19 teeth equals a 19t 7R motor/gearbox...etc...etc...
Here is a link to low priced replacements (gearbox shown for example and you will need to shop the website for the one that you need. looks like they currently have 2 models available):
http://www.goodmans.net/d/1827/power-wh ... rboxes.htm
introduction
