By bigbadwolf
#43422
As anybody compared the http://www.robotcombat.com/products/0-DTXP5737.html) to the traxxas titan 550 motors? I have not found any specs on the Traxxas titan but the specs for duratrax are listed in the link. The duratrax is also half the price of the traxxas. Also it has been stated that the traxxas motors are faster than stock, would these duratraxs also be faster? Would one or the other be better at 18volts?
Thanks in advance for the replies.
By Divinar
#44760
Remove the trailing paranthisis. http://www.robotcombat.com/products/0-DTXP5737.html
The Duratrax are comparable to the super-6, but don't hold up long under 18v.
The Titans do 18v well, but die at 24v.
