By Cinder
#73766
Hi all I am new to the boards. I have a Jeep Hurricane that has a issue. It seems to go forward but will not go in reverse. You can hear the motor turning but the jeep does not move. I noticed that the passenger side rear wheels seems to turn freely and the driver side rear wheel will not turn without resistance. If the issue is a gear box I would like to upgrade to 16T? Is that what I have? What all do I need to get going again. Thanks in advance for all of your responses. Love the site.
By Cinder
#73817
so, this most likely being the issue, what would be the next step. I would like to go with the 16T gearbox. I dont want to have to change out the motor, just the GB. What am I looking for to make sure I order the right parts. Thanks.
#76787
If you hear the motor running it is probably OK. The gearbox or wheel driver is probably bad. Pull off the wheel on the bad side and take a look. Also, note the color of the gear/driver that sticks out of the gearbox. Check the back side of the wheel for damage also.
You cant go to a 16t gearbox without removing the motor. You would have to change the motor or pinion gear. Both will require motor removal.
12v and it’s used
hello I was wrencher on the old site. I am selling[…]
Newbie with need of help
Hi, Picked up an old gator and been trying to get[…]
Two things I think could be happening: #1: The s[…]
