#146166
I have a Peg Gaucho Grande that has been wired for 18v with a relay, 10 gauge wiring, stock 775 motors, terminal block for wiring connections.
When I activate the relay with the motors not hooked up I get 20v at the motor side power connection on the terminal block. When I hook up the motors the power shows up as zero (0) and the motors, of course, do not work. I have run power directly to the motors and they work fine.
I checked the power at the 12v/6v combo and it shows 20v.
The relay set up seems to work fine as when it is activated there is power coming out of the 'motor' side of the relay wiring.
I admit I am a novice wiring guy and I am stumped!! Any thoughts??? Thank you!
By CJB
#146167
It's hard to trouble shoot someone's wiring from afar so I can only speculate. Sounds like a short. :lol:
Recheck all your wires to make sure they go where they should. Verify you didn't mix up your motor wires and such.
A diagram that you used would be helpful to show as well.
By CJB
#146177
ahh yes. The old 'trick battery' problem. :lol:
I have a big old halogen headlight I use in combination with a volt meter to test batteries. Check voltage with no load and then put the headlight load on it and see how much it drops. Shouldn't be more than a volt or two for a decent battery.
