#147913
Hello,
I am hoping to upgrade my son's John Deere Gator from 12v to 18v for a Christmas surprise. I am in need of some very basic help (I apologise for my complete lack of knowledge). I have read lots of topics but I'm still none the wiser. What do I need to buy? A 6v battery with charger? Will the new battery fit inside the existing battery case? What else is needed?
Thanks so much, Clare
#147914
You'll need a 12v battery and a 6v battery of matching AH ratings (i.e. 12V 12AH, 6V 12AH), and at least 1 30A fuse holder and fuse. I like to fuse each battery, but you can get by with fusing the + side of the 12V. Personally, I'd move the batteries to the space under the dump bed and install a charge port for easy recharging.
Also, may I recommend an 18V Interface board to simplify your wiring...
https://www.freewebstore.org/cjbperform ... 92867.aspx
You'll also need a charger capable of 6v and 12v. Most of us use these:
There are many threads on this forum relating to this topic. Dig around and let us know if you have any other questions.
