By Kiwi81uk
#148655
Hi all, guess I need some help, have been looking for a answer but can’t seem to find it ...
I got a 6V Bmw i8 with a 6V engine that I bought in used condition... I thought it was suppose to have 2 engines on bought sides but it only has one ... so to add a second one ... I can just get another one and, connect it ?
Another thing is I want it to go faster, so if I add another battery of 6 to make it 12v ... it won’t fry the lights and the music ? Or it should work fine in 12v ? Also did planned to upgrade the engines to hpi gt 550 but what battery’s are recommended for that? I’ve seen some ppl using lipo ones.... thanks to all
By najnad
#148670
Yes, if you get a second motor/gearbox and are able to mount it properly, it should work with the existing battery/wiring/etc. Just your drive time will be reduced due to the additional drain on the battery.
As for the increase to 12v, if it works it will increase the speed. However, depending on the wiring/circuit board the i8 uses, it may not be able to handle the increase in voltage. The circuit board could fry. I would do some more searches for anyone who has modified an i8 and/or a ride-on made by the same manufacturer to see what they did and what works/doesnt. Good luck!
Hooked up garden dump trailer. Works great. Video[…]
Hello all
Just getting really into Powerwheels. My son has a[…]
Would you guys share pictures of your set up with […]
I’m trying to do this same thing with the Audi ver[…]
