By Bjenness123
#151004
Hello. I recently found a gaucho rockin. Looking for instructions/directions on how to remove the top, or can. It still is holding on the front of the vehicle. I can’t seem to find the points. So I can check if the wires are in the right spot. Any help will be appreciated. It tips, from the rear. I also know I’d have to skip over the steering column.
By Rob222
#151005
There a couple of screws under the yellow marker-lights on top of the front fenders that need to be removed.
The marker-lights are a pain to remove with out breaking them. If you can get away with not removing the complete upper body from the lower then don't.
If you need to remove the marker-lights here's the thread:
http://www.modifiedpowerwheels.com/foru ... C_ID=17001
Without removing the upper body, the motor pan in the rear is easy to remove, the wiring "cover" under the body is easy to remove, the shifter is easy to remove (....). That should give you access to the complete wiring harness for inspection.
Batmobile rehab CB question
The back soldering looks good. The connection is t[…]
Holy Batmobile! Awesome score!
Really thick plastic and well made. older car
Bigfoot 4x4x4
Thanks, that did the trick!
Thanks for posting the info and pictures. Unfortun[…]
