This is a tutorial section. find out how motors, relays, flashers, LED's work.
DO NOT POST HERE, UNLESS ITS A TUTORIAL
#1349
Shifters
The shifters in Battery Powered Ride On (BPRO) toys are used to operate one or more switches. Most Power Wheels and Peg Perego BPROs use Double Pole Double Throw (DPDT) switches capable of carrying the high current needed, directly to the motors. Most Little Tykes, Safety First, and Chinese brands use low current switches, which send signals to a circuit board, which in turn, operates relays that carry high current to the motors.
The following is an example of a typical 12V Power Wheels shifter. This shifter is from an Extreme Machine:
A cam connected to the opposite end of the shifter arm passes over two high Amperage switches. This design assures that each switch can only be operated while the other switch in the correct position, preventing short-ciruits.
12V Power Wheels shifter from top, with cover removed
12V Power Wheels shifter from bottom, with wiring harness attached
Throttle Pedal
The Throttle Pedals in Battery Powered Ride On toys operate a switch. Most Power Wheels and Peg Perego BPROs use Single Pole Double Throw (SPDT) switches capable of carrying the high current needed, directly to the motors. Most Little Tykes, Safety First, and Chinese brands use low current switches, which send signals to a circuit board, which in turn, operates relays that carry high current to the motors.
The following is an example of a typical 12V Power Wheels throttle pedal. This throttle pedal is from an Extreme Machine:
12V Power Wheels Throttle Pedal, with wiring harness attached
Electrical Components
The three switches shown above, are used to redirect electrical current, in order to each provide one of three main functions:
1. Throttle (or Foot) Switch - Starts and stops vehicle travel by either routing electrical current to the motors (go), or shorting the motor leads together which provides resistance to the motors (stop).
2. High/Low Switch - Changes the circuitry of either the batteries (usually older designs), or motors to be in parallel or series, which provides either half battery voltage (low), or full battery voltage (high).
3. Forward/Reverse Switch - Changes the polarity of the motor circuitry to change the direction of motor rotation, which causes the vehicle to travel in either a forward or reverse direction.
The following are examples of the most common wiring configurations found in BPRO vehicles which do not utilize circuit boards in the 'drive-train'.
NOTE: Clicking these diagrams will open a slideshow depicting different switch states, and the resulting circuit configuration. The slideshow can be controlled with your right/left keyboard keys, or by using the on-screen controls below the diagrams
6 Volt Single Battery Wiring Diagram (click to animate)
Super-6 Volt Single Battery Wiring Diagram (click to animate)
12 Volt Single Battery Wiring Diagram (click to animate)
12 Volt Dual Battery (newer style) Wiring Diagram (click to animate)
12 Volt Dual Battery (older style) Wiring Diagram (click to animate)
#17147
This is very awesome info. Now I totally understand about these components. Great Job!!! :D
