By bostonkiter
#147247
24v ESC works great (for now) wired through the stock shift relay.
Where do I add resistance to make braking happen? Right now it rolls forever to a stop.
THANKS IN ADVANCE!
By Hackish
#147385
On a DC motor, it is quite easy to add resistive braking. For a brushless, it's generally a function of the ESC. It has it or it doesn't. Most of the ESCs I've seen use a PWM drive from an RC servo control system so those with speed control can also use a PWM ramp-down to control braking. I didn't go forward with BLDC and ESC for the toy I have because of cost and the amount of time I have available. Hope that helps.
By k_dub09
#147968
most all escs have programmable braking. look up your specific model and find the programming guide. brushed motors are used in scale crawling all the time with a drag brake setup.
Hello everyone, I got a Gaucho (first type i think[…]
If you are still searching for I have available s[…]
Sounds like your just using low gear and reverse o[…]
Man, you are amazing! Really! I am from Brazil an[…]
