By slybunda
#149894
hi all, i got a ride on car that was not driving right and making a iffy sound. i opened up the gearbox and found one tooth to be broken from a cog/gear. is it possible to get a replacement gear?
the size of the broken gear is:
8mm shaft
62.2mm outer diameter 61 teeth
18.2mm inner cog diameter 11 teeth
pics attached:
thanks
Batmobile- 1992 Power Drivers
Plasti-dip
